Easy way for an Are you sure dialog in automation script
Solved1.90K views27th June 2022automation scripts dialog
Gerwin van der Kamp [DevOps Advocate]3.60K 24th June 2022 0 Comments
is there an easy to get an Are you sure you want to continue message box with an automation script without building an complete ui with the uibuilder?
https://docs.dataminer.services/user-guide/Advanced_Modules/Automation/Using_CSharp/Building_interactive_Automation_scripts_with_CSharp.html
Joey Vanhalst [SLC] [DevOps Advocate] Answered question 27th June 2022
Miguel Obregon [SLC] [DevOps Catalyst]22.03K Posted 24th June 2022 1 Comment
Hi Gerwin,
I am not sure if it will help, but a possible option is to use the action 'User interaction' (DataMiner Docs - User Interaction):
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 24th June 2022
Gerwin van der Kamp commented 24th June 2022
Might be an option, the rest is c# code though, but maybe i can use this. I’ll have look.
