Easy way for an Are you sure dialog in automation script
Solved2.41K views27th June 2022automation scripts dialog
Gerwin van der Kamp [DevOps Advocate]4.09K 24th June 2022 0 Comments
is there an easy to get an Are you sure you want to continue message box with an automation script without building an complete ui with the uibuilder?
https://docs.dataminer.services/user-guide/Advanced_Modules/Automation/Using_CSharp/Building_interactive_Automation_scripts_with_CSharp.html
Joey Vanhalst [SLC] [DevOps Advocate] Answered question 27th June 2022
Joey Vanhalst [SLC] [DevOps Advocate]2.17K Posted 27th June 2022 1 Comment
You could use the following method to show a message box (with a custom message in this case):
private static bool Confirm(IEngine engine, string message)
var uiBuilder = new UIBuilder();
uiBuilder.Append(message);
uiBuilder.AppendButton(“okBtn”, “OK”);
uiBuilder.AppendButton(“cancelBtn”, “Cancel”);
var uiResults = engine.ShowUI(uiBuilder);
return uiResults.WasButtonPressed(“okBtn”);
This will then return true/false depending if the user confirmed or not.
Also note that this does imply that the script is executed by a user. If not, you’ll need to use “FindInteractiveClient” so a user can first attach to the script.
Gerwin van der Kamp commented 27th June 2022
I was afread it would be indeed using the UIbuilder, but this seems simple enough 🙂
Miguel Obregon [SLC] [DevOps Catalyst]23.71K Posted 24th June 2022 1 Comment
Hi Gerwin,
I am not sure if it will help, but a possible option is to use the action ‘User interaction’ (DataMiner Docs – User Interaction):
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 24th June 2022
Gerwin van der Kamp commented 24th June 2022
Might be an option, the rest is c# code though, but maybe i can use this. I’ll have look.
