DynamicUnits trending and alarm values behavior
Solved568 views6th November 2025
Stefan Schedletzky [DevOps Advocate]2.48K 27th August 2025 0 Comments
I have a network parameter in a table and I'm not 100% sure about the DynamicUnits.
Parameter:
Alarms:
Trending:
Do I need to add DynamicUnits tag to the parameter? Or should I recalculate the parameter to Mbps and set this as <Units>?
Stefan Schedletzky [DevOps Advocate]2.48K Posted 27th August 2025 0 Comments
Recalculate the value and set it to Mbps fix the problem
