Dynamic Positioning of single element
Solved3.56K views13th October 2023dynamic position
Dominique Bodart [DevOps Member]783 3rd April 2023 1 Comment
I want to automatically position some elements on a map, based on coordinates. To proceed, I defined a single shape on vision with those properties:
Xpos [Parameter:site_lon]
Ypos [Parameter:site_lat]
Element 5302/2223
Info ELEMENT NAME
Parameters are labelled as per above but no shape appears ...
I tried the map when to display the element with a table using the same coordinates and it works fine, so I thing the map itself is ok. Do you have any suggestion?
And will it be possible to replace the element IP by [auto] or protocol to automatically position all elements alike?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 13th October 2023
Marieke Goethals [SLC] [DevOps Catalyst] commented 6th July 2023
Have you been able to solve the issue with these answers? If so, could you select the best answer (using the ✓ icon)? If not, you can also contact techsupport@skyline.be for assistance.
Dominique Bodart [DevOps Member]783 Posted 6th April 2023 0 Comments
But in my case, I need to automatically place about 40 shapes on a map, each shape representing an onsite device. So, as it is not possible to dynamically position per protocol, I rewrote the driver to gather all the element info's in a single table with one entry per device. That way, it works fine. Saying that, several elements are sharing the same position on the map, so they only appear as single shape. Is there a quick way to separate them a little bit from each other, but knowing that I use Viso 2016 which doesn't seem to support DynamicZoom and grouping?
Dominique Bodart [DevOps Member] Answered question 6th April 2023
You are viewing 1 out of 5 answers, click here to view all answers.
