Dynamic Positioning of single element
Solved3.55K views13th October 2023dynamic position
Dominique Bodart [DevOps Member]783 3rd April 2023 1 Comment
I want to automatically position some elements on a map, based on coordinates. To proceed, I defined a single shape on vision with those properties:
Xpos [Parameter:site_lon]
Ypos [Parameter:site_lat]
Element 5302/2223
Info ELEMENT NAME
Parameters are labelled as per above but no shape appears ...
I tried the map when to display the element with a table using the same coordinates and it works fine, so I thing the map itself is ok. Do you have any suggestion?
And will it be possible to replace the element IP by [auto] or protocol to automatically position all elements alike?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 13th October 2023
Marieke Goethals [SLC] [DevOps Catalyst] commented 6th July 2023
Have you been able to solve the issue with these answers? If so, could you select the best answer (using the ✓ icon)? If not, you can also contact techsupport@skyline.be for assistance.
Ben Vandenberghe [SLC] [DevOps Advocate]9.76K Posted 3rd April 2023 0 Comments
Just as an additional note here on the topic for those who are interested: there is a sample implementation of this available on the online reference DataMiner System accessible with your Dojo account: https://ziine.skyline.be/ (along with other reference Visual Overview techniques)
Go to the view Operations > Other > Visual Overview Design Examples
And then to the tab page 'positioning' > DYNAMIC
There is an element there that is dynamically positioned.  If you right click on the Visual Overview canvas and click 'arrange', you can drag the element to a new position and click Apply on the top right to store the new location.  On the element you can right click > properties > custom where you can then see the AxisX and AxisY property that hold the positioning metrics.
Ben Vandenberghe [SLC] [DevOps Advocate] Edited answer 3rd April 2023
You are viewing 1 out of 5 answers, click here to view all answers.
