Dynamic Positioning of single element
Solved3.85K views13th October 2023dynamic position
Dominique Bodart [DevOps Member]783 3rd April 2023 1 Comment
I want to automatically position some elements on a map, based on coordinates. To proceed, I defined a single shape on vision with those properties:
Xpos [Parameter:site_lon]
Ypos [Parameter:site_lat]
Element 5302/2223
Info ELEMENT NAME
Parameters are labelled as per above but no shape appears ...
I tried the map when to display the element with a table using the same coordinates and it works fine, so I thing the map itself is ok. Do you have any suggestion?
And will it be possible to replace the element IP by [auto] or protocol to automatically position all elements alike?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 13th October 2023
Marieke Goethals [SLC] [DevOps Catalyst] commented 6th July 2023
Have you been able to solve the issue with these answers? If so, could you select the best answer (using the ✓ icon)? If not, you can also contact techsupport@skyline.be for assistance.
Ben Vandenberghe [SLC] [DevOps Advocate]9.77K Posted 3rd April 2023 4 Comments
Hi Dominique - I have no hands-on experience on this, but wanted to see if I can already help you out.  Firstly, did you check on this documentation Positioning shapes dynamically | DataMiner Docs about dynamically positioning?
Also I was wondering, are you trying to dynamically position on a Visual Overview graphic, or a Google Maps?  I wasn't entirely sure reading your question if you were referring to one or the other.
Robin Becker [DevOps Member] Posted new comment 6th April 2023
Dominique Bodart [DevOps Member] commented 3rd April 2023
Hi Ben,
For this, I followed training’s Michiel about Dynamic Positioning. It works well with table. But What I want to do here is to do the same for a single element which also hold lat / lon where to by displayed. But dor single element, the documentation only mentions “property”, not “parameter” or “param” like in the case of a table.
Ben Vandenberghe [SLC] [DevOps Advocate] commented 3rd April 2023
For a single element, if it does not have parameters that hold its position, then typically this is based on a property of an element.
Here you can find more information about those properties https://docs.dataminer.services/user-guide/Basic_Functionality/Elements/About_elements/Element_properties.html and how to add them https://docs.dataminer.services/user-guide/Basic_Functionality/Elements/Working_with_elements/Managing_element_properties.html
Let us know if this helps out or if we are still missing something to get your implementation to work.
What I did, I modified the protocol to put all retrieved parameter in a table and if I assign the Shape Data as follow, it works for the mentionned element ID “5302/2223”:
Xpos: [param:5302/2223,2000]
But I have about 40 elements like that, using the same protocol. So is there a way to “tell” Xpos to fetch elements using the same protocol and version? I tried [param:*,2000] but no luck 🙂
Robin Becker [DevOps Member] commented 6th April 2023
Dominique, did you get it to work? You can use table indexes when using the [Param:]-placeholder. Combine this with https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/generating_shapes/Generating_shapes_based_on_table_rows.html and you should be able to loop trough every row of a protocol table.
You are viewing 1 out of 5 answers, click here to view all answers.
