Dynamic Positioning of single element
Solved3.58K views13th October 2023dynamic position
Dominique Bodart [DevOps Member]783 3rd April 2023 1 Comment
I want to automatically position some elements on a map, based on coordinates. To proceed, I defined a single shape on vision with those properties:
Xpos [Parameter:site_lon]
Ypos [Parameter:site_lat]
Element 5302/2223
Info ELEMENT NAME
Parameters are labelled as per above but no shape appears …
I tried the map when to display the element with a table using the same coordinates and it works fine, so I thing the map itself is ok. Do you have any suggestion?
And will it be possible to replace the element IP by [auto] or protocol to automatically position all elements alike?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 13th October 2023
Marieke Goethals [SLC] [DevOps Catalyst] commented 6th July 2023
Have you been able to solve the issue with these answers? If so, could you select the best answer (using the ✓ icon)? If not, you can also contact techsupport@skyline.be for assistance.
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 13th October 2023 0 Comments
As this question has been inactive for a long time, we will now close it. If you want further assistance, feel free to post a new question.
6
Dominique Bodart [DevOps Member]783 Posted 3rd April 2023 0 Comments
Just to add on, I try to display to dynamic shapes on a Viso representing a map, not on Google map.
Dominique Bodart [DevOps Member] Answered question 3rd April 2023
6
Ben Vandenberghe [SLC] [DevOps Advocate]9.76K Posted 3rd April 2023 4 Comments
Hi Dominique – I have no hands-on experience on this, but wanted to see if I can already help you out.  Firstly, did you check on this documentation Positioning shapes dynamically | DataMiner Docs about dynamically positioning?
Also I was wondering, are you trying to dynamically position on a Visual Overview graphic, or a Google Maps?  I wasn’t entirely sure reading your question if you were referring to one or the other.
Robin Becker [DevOps Member] Posted new comment 6th April 2023
Dominique Bodart [DevOps Member] commented 3rd April 2023
Hi Ben,
For this, I followed training’s Michiel about Dynamic Positioning. It works well with table. But What I want to do here is to do the same for a single element which also hold lat / lon where to by displayed. But dor single element, the documentation only mentions “property”, not “parameter” or “param” like in the case of a table.
Ben Vandenberghe [SLC] [DevOps Advocate] commented 3rd April 2023
For a single element, if it does not have parameters that hold its position, then typically this is based on a property of an element.
Here you can find more information about those properties https://docs.dataminer.services/user-guide/Basic_Functionality/Elements/About_elements/Element_properties.html and how to add them https://docs.dataminer.services/user-guide/Basic_Functionality/Elements/Working_with_elements/Managing_element_properties.html
Let us know if this helps out or if we are still missing something to get your implementation to work.
What I did, I modified the protocol to put all retrieved parameter in a table and if I assign the Shape Data as follow, it works for the mentionned element ID “5302/2223”:
Xpos: [param:5302/2223,2000]
But I have about 40 elements like that, using the same protocol. So is there a way to “tell” Xpos to fetch elements using the same protocol and version? I tried [param:*,2000] but no luck 🙂
Robin Becker [DevOps Member] commented 6th April 2023
Dominique, did you get it to work? You can use table indexes when using the [Param:]-placeholder. Combine this with https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/generating_shapes/Generating_shapes_based_on_table_rows.html and you should be able to loop trough every row of a protocol table.
Ben Vandenberghe [SLC] [DevOps Advocate]9.76K Posted 3rd April 2023 0 Comments
Just as an additional note here on the topic for those who are interested: there is a sample implementation of this available on the online reference DataMiner System accessible with your Dojo account: https://ziine.skyline.be/ (along with other reference Visual Overview techniques)
Go to the view Operations > Other > Visual Overview Design Examples
And then to the tab page ‘positioning’ > DYNAMIC
There is an element there that is dynamically positioned.  If you right click on the Visual Overview canvas and click ‘arrange’, you can drag the element to a new position and click Apply on the top right to store the new location.  On the element you can right click > properties > custom where you can then see the AxisX and AxisY property that hold the positioning metrics.
Ben Vandenberghe [SLC] [DevOps Advocate] Edited answer 3rd April 2023
Dominique Bodart [DevOps Member]783 Posted 6th April 2023 0 Comments
But in my case, I need to automatically place about 40 shapes on a map, each shape representing an onsite device. So, as it is not possible to dynamically position per protocol, I rewrote the driver to gather all the element info’s in a single table with one entry per device. That way, it works fine. Saying that, several elements are sharing the same position on the map, so they only appear as single shape. Is there a quick way to separate them a little bit from each other, but knowing that I use Viso 2016 which doesn’t seem to support DynamicZoom and grouping?
Dominique Bodart [DevOps Member] Answered question 6th April 2023
