Dummy element
Solved2.86K views5th May 2022elements Rack View
Thomaz Malmberg [DevOps Member]523 5th May 2022 0 Comments
Is there any way that I can create an "dummy" element that should be visible in my rack view? I have racks with elements that we don´t have included in DM, but we will see them in the rack view.
// Thomaz
Jeroen Geldhof [SLC] [DevOps Enabler] Answered question 5th May 2022
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 5th May 2022 0 Comments
Hi Thomaz,
For this case we normally use a dummy connector. This dummy connector does not perform any polling, it allows you to create an element that can be used for your rack overview. An example of dummy connector can be found in the catalog (Generic Dummy).
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 5th May 2022
