Dual IP and failover for Dataminer elements
Solved647 views18 hours ago
Bhavana Malviya99 4th July 2025 2 Comments
Hi Techsupport
Is it possible to configure two different Management IPs for each element in Dataminer, and can Dataminer Polling failover to second IP when first IP of an element gets unreachable ?
Please provide steps to configure SNMP for this Dual IP.
Thanks.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 18 hours ago
I see that this question has been inactive for some time. Do you still need help with this? If not, could you select the most relevant answer (using the ✓ icon) to indicate that no further follow-up is needed?
Marieke Goethals [SLC] [DevOps Catalyst] commented 18 hours ago
Laurens Moutton [SLC] [DevOps Enabler]9.62K Posted 4th July 2025 0 Comments
That is possible with a feature called "Redundant polling". However, this requires a change to the protocol.xml of the connector. More info can be found here.
Regards,
