Dual IP and failover for Dataminer elements
Solved641 views16 hours ago
Bhavana Malviya99 4th July 2025 2 Comments
Hi Techsupport
Is it possible to configure two different Management IPs for each element in Dataminer, and can Dataminer Polling failover to second IP when first IP of an element gets unreachable ?
Please provide steps to configure SNMP for this Dual IP.
Thanks.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 16 hours ago
I see that this question has been inactive for some time. Do you still need help with this? If not, could you select the most relevant answer (using the ✓ icon) to indicate that no further follow-up is needed?
Marieke Goethals [SLC] [DevOps Catalyst] commented 16 hours ago
Laurens Moutton [SLC] [DevOps Enabler]9.62K Posted 4th July 2025 0 Comments
That is possible with a feature called "Redundant polling". However, this requires a change to the protocol.xml of the connector. More info can be found here.
Regards,
Bhavana Malviya99 Posted 11th July 2025 1 Comment
Hi Laurens,
As I followed the documentation I have add the command in protocol XML file,but in dataminer cube failover option not showing can you guide where we can add failover IP.
Laurens Moutton [SLC] [DevOps Enabler] Posted new comment 5th November 2025
Laurens Moutton [SLC] [DevOps Enabler] commented 5th November 2025
Hi, as there was no comment added to my answer, I was not notified that new info was added to this separate answer, hence why I only saw this now. To come back to this issue: adding communicationOptions="redundantPolling" advanced="snmpv2:Secondary" to the Type tag in the Protocol.xml should show an extra connection "Secondary" where extra SNMP IP address etc can be set when creating an element.
Regards,
