DropDown issue on Low Code App
Solved1.37K views19th September 2024dropdown LCA low code app
Dario Sarkanovic [SLC] [DevOps Advocate]1.20K 17th September 2024 0 Comments
I’m working on Low Code App which will show some columns from protocol in dropdown list component on Low Code App. I made query to select column from protocol table and assign that query to DropDown component. The issue is that I don’t get values from table column in my DropDown component.
This is made on following versions:
Web: 10.4.3 (CU0) Server: 10.4.0.0-14003 API: 10.4.2405.2098 App: 10.4.2405.2902
I tried same thing on squad DMA and it works. When I tried it for test on squad DMA, on DropDown Layout Tab I found under Advanced tab “Display Column” option which is not present on Customer DMA like it’s displayed on image above.
Our squad DMA has following version:
Web: 10.4.7 (CU0)
Server: 10.4.7.0-14517
API: 10.4.2421.2614
App: 10.4.2421.1930
I would like to know is this related to version and if it is, how I can display data from protocol columns in DropDown components in Low Code App?
Kind Regards,
Dario.
Dario Sarkanovic [SLC] [DevOps Advocate] Selected answer as best 19th September 2024
Wout Mahieu [SLC] [DevOps Catalyst]12.34K Posted 17th September 2024 0 Comments
Hi Dario
You are indeed seeing different visualizations because of the different versions. With DataMiner 10.3.0[CU13]/10.4.0[CU1]/10.4.4, we introduced the ability to show the results of a query in a dropdown component. Before 10.4.4, you would only see the query itself as an option. Upgrading your system (web-only) to one of these versions will have this feature.
