drag and drop re-ordering in low-code
Solved1.33K views28th August 2024low-code
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 1st July 2024 0 Comments
is there a possibility for drag and drop re-ordering of dom instances in a low-code app?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th August 2024
Thomas Ghysbrecht [SLC] [DevOps Enabler]5.79K Posted 15th July 2024 2 Comments
Hi Jeroen, can you maybe clarify the goal exactly? How are the DOM instances visualized? Is this using the table component?
In DOM, there is no inherent order to the DOM instances. They have values associated where you can sort on. If you want to have a custom order, you could introduce a value that could be used for this (e.g. a sorting integer).
Jeroen Geldhof [SLC] [DevOps Enabler] commented 16th July 2024
The idea was indeed to display the instances in a table and to sort them according to an integer value.
By dragging and dropping the integer values for the instances would be updated to display them higher or lower in the table.
Thomas Ghysbrecht [SLC] [DevOps Enabler] commented 16th July 2024
As far as I am aware, the table component does not support drag/drop functionality and the associated events to trigger on. Currently, this could be solved with buttons where you select the row, click a button and then using an interactive script, allow the user to alter the position of the selected row.
