Double entry for an Ad account in Dataminer system, how to remove?
Solved987 views11th December 2023
Juho Pentinmikko [DevOps Member]88 7th December 2023 0 Comments
We have somehow managed to get a double entry for an Ad account on our system.
I Think that this was made possible by an circular / recursive nesting of the account in groups that had the account and also had some other groups nested within that group that also contained the account as a member.
We have now removed these circular group membership references and ran the LDAP synchronization task on the active DMA but the the account still exist twice in the system.
The delete context menu is not active for the account.
Is there a way to forcibly remove the user on Dataminer end, or should the user be removed from all the Ad groups that allow him access to DM, run the synch task, and add the user back to all relevant groups?
Thanks in advance 🙂
Juho Pentinmikko [DevOps Member] Selected answer as best 11th December 2023
Davy Degrande [SLC] [DevOps Advocate]1.76K Posted 11th December 2023 1 Comment
Hello Juho,
If the user has the exact same name attribute in the C:\Skyline DataMiner\Security.xml then a DMA restart should solve the problem. At the launch we verify our XML files and remove duplicate users if any are detected.
Juho Pentinmikko [DevOps Member] commented 11th December 2023
Ok, we will check this after the next restart of the system, thanks Davy!
