DOM: Using GetFieldValue
Solved1.41K views23rd January 2025DOM
Carlos Matheus [SLC] [DevOps Advocate]371 16th August 2024 0 Comments
I am currently retrieving data from a DOM instance and need to retrieve a field value with the type GenericEnumFieldDescriptor, where the enum type is int.
I could use instance.GetFieldValue<int>(sectionName, fieldValueName, domCache);, but this will only retrieve the enum value, and I need to use the display name instead. Is there a way to retrieve the display name using .GetFieldValue?
Thank you!
Jens Vandewalle [SLC] [DevOps Advocate]10.07K Posted 19th August 2024 1 Comment
Hi Carlos,
This is not possible.
What you can do is using the DOM Editor to generate c# code based on your definitions/sections/field descriptors and use that enum class to do your mapping.
Thomas Ghysbrecht [SLC] [DevOps Enabler] commented 19th August 2024
Defining the value to display value mapping in the script as Jens suggest is the most performant way of doing this. If you however would want to make this more generic and dynamic, you could also just retrieve the SectionDefinition, and get the enum mapping dynamically like that.
