Dolby DP580 Reference Decoder connection
Solved2.26K views19th July 2023API Dolby driver
Henrique Campos 30th March 2021 0 Comments
I´d be glad if could someone help on that topic.
When monitoring the DP580 Reference Decoder trough DataMiner, it is presenting 404 Error. I´d like to ask someone that has it under monitoring, how have this device been configured by You to provide information to DataMiner. The actual version of this device is "Version 1.1.0.8". Can you also share the default "Advanced Password"?
Here is the actual Streamviewer result:
HTTP/1.1 404 Not Found
-> 15:17:26 - Get for statusStatusCode () returned VT_BSTR : HTTP/1.1 404 Not Found
-> 15:17:26 - Get for statusResponseData () returned VT_BSTR : <html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1"/>
<title>Error 404 Not Found</title>
</head>
<body><h2>HTTP ERROR 404</h2>
<p>Problem accessing /ws/v1/status. Reason:
<pre> Not Found</pre></p><hr /><i><small>Powered by Jetty://</small></i><br/>
Fenta Alemahu [SLC] [DevOps Advocate]1.32K Posted 31st March 2021 1 Comment
Hi Henrique,
The Dolby DP580 connector is developed based on version 2.5.0.5 of the device API. So, it could be that the service that dataminer is requesting is not available for version 1.1.0.8 at that location (/ws/v1/status). Is it possible for you to upgrade the software version to 2.5.0.5 and test the connector on this version? If it is not possible to upgrade the software version of the device at this point, can you provide us the API information from  http://[DP580]/ws/v1/api/reference.html, where DP580 is the hostname or IP address of your system?
Henrique Campos commented 31st March 2021
Thank You Fenta, the Customer will ask for the newest firmware to Dolby since the actual version has no reference.html page; I think this range 1.x had no API available yet. Thanks for letting me know the correct version you are using for this driver.
