DoJo question issue
Solved1.83K views28th August 2023
Philip Argent [DevOps Advocate]1.02K 25th August 2023 0 Comments
I’m trying to add a question with some regex examples in that won’t submit, it just sits there with the spinning circle at the end of submit question.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th August 2023
Thibault Heylen [SLC] [DevOps Member]1.51K Posted 28th August 2023 0 Comments
Can you post your regex as an image so we can check where it goes wrong?
I assume a validation is getting stuck, but with the regex we can then verify it.
