Does trending work correctly for discreet string parameters?
Solved2.37K views19th July 2023trending
Ruben Vandepitte [SLC] [DevOps Advocate]2.41K 11th March 2021 0 Comments
It has always been best-practice to not trend regular string parameters, for obvious reasons.
I wonder though if the same applies to string parameters of type ‘discreet’?
What are the specific features – could be client and/or server side – which are not supported for such parameters?
Should we always aim to convert these to numerical discreets?
What’s Skyline’s advise on this?
Wim Bruynooghe [SLC] [DevOps Advocate]6.78K Posted 11th March 2021 0 Comments
Trending on string parameters (including string discreets) are not supported in the web and mobile applications (Reports & Dashboards, Monitoring, Custom apps, WebAPIs). So if you want to view the trending in these apps it will be better to use numerical discreets.
Toon Casteele [SLC] [DevOps Enabler]7.45K Posted 15th March 2021 0 Comments
In DataMiner Cube, discreets can all be visualized. They will be evenly distributed on the y axis. Differences with numerical data:
  • There is no numeric averaging. This means that the background area for min/max values will be shown across the entire y range from the moment a discreet average point didn’t occur across the entire time slot.
  • There is no minimum and maximum value for the average points. Instead these contain
    • info on how much of the time the average value (the value that occurred the longest) actually occurred (in %)
    • What the median value was (aka the value that was set the most times in the time slot)
For string trending, there’s an added difference:
  • At most, 20 different values will be visualized. If there are any more, they will be categorized on y axis value “(other)”.
Toon Casteele [SLC] [DevOps Enabler] Edited answer 15th March 2021
