Does Maps/Cube supports Geometry data?
Solved2.97K views18th July 2023coordinates Geometry Google Maps maps Open Street Maps
Arturo Lizcano [SLC] [DevOps Member]471 13th April 2021 0 Comments
Hi everyone,
Context:
We are implementing a connector to geolocate some subscribers on a map based on the data stored in PostgreSQL. To achieve that, we could use the latitude and longitude (at this moment, they are empty) of each entry as well as a Geometry datatype:
If a user clicks in the "Eye," all the points are automatically located in an empty canvas:
In other tables, we have the Coverage of some devices, stored again as geometry, but in this case, it is a polygon:
The geometry data type is used because it is supposed to be much nicer on the system resources than to load the coordinates one by one or load KML on a map.
Question time:
Are the Maps engines that DataMiner Cube supports able to use this type of data? If so, where could we find more information about it?
Wim Bruynooghe [SLC] [DevOps Advocate]6.77K Posted 14th April 2021 0 Comments
DataMiner Maps makes use of data that is available in DataMiner, like a parameter table, element parameters, element properties, or even a table stored in a database of DataMiner (db.xml). If that's the case, then it's possible to display this data on a map as markers or as (poly-)lines. See the Help for more information.
