Does is posible authentication logins to agent DMA via ADFS using SAML or OpenID.
Solved435 views5th January 2026
Jaroslaw Burtny [DevOps Member]756 27th November 2025 0 Comments
Hi All.
Please let me know if it's possible to authenticate logins to agent DMA via ADFS using SAML or OpenID. ADFS supports 2FA.
Big thanks for answer.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 5th January 2026
Christine Kapembe [SLC] [DevOps Advocate]1.01K Posted 23rd December 2025 0 Comments
A ticket was raised for this enquiry, and guidance on the correct configuration was provided.
If you would like to configure SAML with ADFS, please refer to the following guide:
Configuring SAML with Microsoft Entra ID as identity provider | DataMiner Docs
You will need to configure the corresponding settings on ADFS as outlined in the documentation.
SSO is now working for both Cube and web apps.
