Does is posible authentication logins to agent DMA via ADFS using SAML or OpenID.
Solved437 views5th January 2026
Jaroslaw Burtny [DevOps Member]756 27th November 2025 0 Comments
Hi All.
Please let me know if it's possible to authenticate logins to agent DMA via ADFS using SAML or OpenID. ADFS supports 2FA.
Big thanks for answer.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 5th January 2026
Bert Vandenberghe [SLC] [DevOps Enabler]9.68K Posted 28th November 2025 0 Comments
Hi Jaroslaw,
DataMiner supports SAML. Therefore, it should be possible to authenticate against any SAML identity provider, also ADFS. I am although not aware of anybody who's using this identity provider, and this one is not documented in our docs. But in theory, it should work, and if you would experience any unexpected behavior, we are here to help you out.
That being said, we do use Entra ID a lot. This is now the most frequently used SAML identity provider and also documented here: Configuring SAML with Microsoft Entra ID as identity provider | DataMiner Docs. So, in case you do have Entra ID as well (previously known as Azure Active Directory), it might be worth authenticating directly against Entra ID because this has some extra advantages like Identity Protection.
Let us know if you have any additional questions.
Bert
Bert Vandenberghe [SLC] [DevOps Enabler] Answered question 28th November 2025
