Does is posible authentication logins to agent DMA via ADFS using SAML or OpenID.
Solved433 views5th January 2026
Jaroslaw Burtny [DevOps Member]756 27th November 2025 0 Comments
Hi All.
Please let me know if it's possible to authenticate logins to agent DMA via ADFS using SAML or OpenID. ADFS supports 2FA.
Big thanks for answer.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 5th January 2026
Seppe Dejonckheere [SLC] [DevOps Enabler]2.74K Posted 28th November 2025 0 Comments
DataMiner does support SAML authentication, so it should be possible to integrate with any identity provider that support SAML as well. More details about configuring SAML in DataMiner can be found in the DataMiner docs.
Kind regards,
Seppe Dejonckheere [SLC] [DevOps Enabler] Answered question 28th November 2025
