Does both agents in failover pair suppose to create backups irregardless of state?
Solved1.37K views6th June 2024
Dennis Nacorda182 28th March 2024 0 Comments
I have three failover pairs in a cluster, one of them I just added recently. The first two failover pairs are creating backup irregardless of who is online or offline. When I added the third pair and scheduled the backup, I observed that only the online agent is creating the backup (I have not tried to switch to the offline agent).
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 6th June 2024
Michiel Saelen [SLC] [DevOps Advocate]6.56K Posted 29th March 2024 2 Comments
Hi Dennis,
I would expect that only the active agent creates backups. Can you double-check that the backups on the inactive were created recently? Maybe these backups are there from when it was active?
Dennis Nacorda commented 30th March 2024
Hi Michiel,
The backups on the inactive agents are being created at the same time with the active agents.
Michiel Saelen [SLC] [DevOps Advocate] commented 30th March 2024
I would raise this as an issue under Maintenance and Support. If you want to look a bit further yourself, you can look at the failover configuration in the DMS.xml (C:Skyline DataMiner) on both agents and have a look at what the SLFailover.txt log file (C:Skyline DataMinerLogging) tells you.
