Does Alarm Storm group alarms per protocol ?
Solved1.10K views30th June 2023Cube
Bernard Pichot [SLC] [DevOps Advocate]1.32K 29th June 2023 0 Comments
The alarm storm configuration mention "grouping alarms with the same parameter name (Alarm Console)".
Does the alarm storm use only the parameter name or also the protocol ?
if we have two protocols with same parameter label, for example "Criticity" raised alarms, does this generate 1 or 2 different alarm storm ?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th June 2023
Michaël Pincket [SLC] [DevOps Advocate]1.96K Posted 29th June 2023 0 Comments
Hi Bernard,
The alarm storm will use the parameterdescription of the alarm to detect if the parametername is the same. This means that the protocol will not be taken into account and in your example it will generate only one alarm storm.
