Document Folder not appeaing in Documents Module
Solved1.03K views12th September 2025DMA Document folders documents files sync
Amber Rowe [DevOps Advocate]575 2nd June 2025 1 Comment
Hello!
My issue is: I created a folder on the actual Windows server of a DMA on the Local Disk. I should now expect to see that folder in the document module, right?
I used the tools in the System Centre to sync the DMA / DMS / File, but it's not appearing.
So, what else can I do to make it visible in the documents folder for other users to see, without having the user log in to the VM hosting the DMA?
Kind regards,
Steve Purcell [SLC] [DevOps Advocate] commented 2nd June 2025
Hi Amber, What directory did you create the folder under on the Windows Server? If you create under C:Skyline DataMinerDocuments you should see in cube the next time you open Documents.
Jose Araujo [DevOps Advocate]1.01K Posted 4th June 2025 0 Comments
Hi Amber,
After uploading a file to Documents, you must restart the application for it to be visible in the Documents section in Cube.
Thanks
