DMS communication problem between agents
1.45K views7th August 2026DMA DMS SLNet
Isabel Arce [DevOps Member]214 10th June 2026 0 Comments
We recently updated a cluster of 3 dataminer agents to version 10.6 CU3. Accessing the cluster from DMA1 and DMA2 shows all 3 agents connected, but accessing it from DMA3 shows DMA2 and DMA1 in an "Unknown" state. We've verified connectivity between the 3 agents via ports 443, 8004, and 80. Would it be helpful to send a "SetConnectionUriMessage" message to resolve this issue? What fields would be required to send this message? Is there another way to resolve this problem? Thank you in advance.
Juan Nicola [SLC] [DevOps Advocate] Answered question 7th August 2026
Edson Alfaro [SLC] [DevOps Advocate]1.79K Posted 10th June 2026 0 Comments
Hi Isabel,
I've solved that issue in the past using the connection strings as you mentioned.
Here is the documentation that explains how to configure it from the SLNetClientTest tool:
Editing the connection string between two DataMiner Agents | DataMiner Docs
Regards.
Edson Alfaro [SLC] [DevOps Advocate] Answered question 10th June 2026
