DMA View Audit Logs Module
Solved897 views7th November 2023Audit
Vikas Choudhary [DevOps Member]576 6th November 2023 0 Comments
Hello Dojo Community,
Do we have inbuild audit module where Admin can check who made the changes for particular element or protocol or service, what was old values what is changed value etc.
  1. Admin can filter based on any element(s) or protocol(s)
  2. Admin can filter particular user name also, it will give all changes made by that user in DMA
  3. It should return old value and changed value
  4. it should contain all history since DMA agent installed or element/service added
Thanks
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 7th November 2023
Miguel Obregon [SLC] [DevOps Catalyst]22.38K Posted 6th November 2023 0 Comments
Hi Vikas,
I believe this information is available in information events:
  • Admin can filter based on any element(s) or protocol(s)
    In the alarm console you can filter based on element/protocol. Every time that there is an update on a particular element, this action will registered in an information event
  • Admin can filter particular user name also, it will give all changes made by that user in DMA
    When a set is performed in a particular element, the username that performed this action is registered in the information event.
  • It should return old value and changed value
    You can retrieve the previous value as long as the parameter is trended.
  • It should contain all history since DMA agent installed or element/service added
    This will depend of the TTL configured in the cluster.
Hope it helps.
