DM Cube connection problem
Solved1.54K views7th November 2023Connection State DM Cube
Manuel Gallardo [DevOps Advocate]811 6th November 2023 0 Comments
We have several DM Cube users that have a problem with the connection. Sometimes, after start the Cube, it keeps frozen in the “Connected” message. The problem seems to be resolved after make a clean up but the problem reapperars after a few days.
Is there any known issue or a way to prevent it?
Thanks in advance!.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 7th November 2023
Michaël Pincket [SLC] [DevOps Advocate]2.13K Posted 6th November 2023 2 Comments
Hi Manuel,
We are aware of this issue and have a fix ready. This fix will be released in the following versions: 10.2.0[CU22], 10.3.0[CU10] and 10.4.1.
Manuel Gallardo [DevOps Advocate] commented 6th November 2023
Thanks for the reply Michaël, is there an estimated date for the release?
Michaël Pincket [SLC] [DevOps Advocate] commented 6th November 2023
Hi Manuel,
The release of the above mentioned versions if foreseen for December 15th.
