Display Property UserData does not show content Visio View – Max Length Exceeded?
Solved1.57K views17th October 2023
Oliver Wilkinson [DevOps Advocate]917 25th May 2023 2 Comments
Hello,
We have a service with a custom property of "UserData" as well as several others. The UserData property is used to store some config JSON.
When attempting to display the Property Value for the UserData no content is shown and the shape is not displayed however if I change nothing else apart from the property name to another which only has a single word the property is displayed.
I wondered, if there is a limit on the amount of content that can be displayed or if maybe there is something else which might be going on here that I am unaware of
Many thanks
Oliver
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 17th October 2023
Toon Casteele [SLC] [DevOps Enabler] commented 26th May 2023
How are you displaying the property (what shape data, shape text…) and what is the property’s value? This might help us identify the issue as it probably has something to do with characters being used as separators that are also present in your property value.
Marieke Goethals [SLC] [DevOps Catalyst] commented 5th July 2023
Hi Oliver,
I noticed that this question has been open for some time now. Have you been able to find a solution yet? If not, could you provide us with more information so we can help you further?
Edith Lansens [SLC] [DevOps Member]791 Posted 17th October 2023 0 Comments
As this question has now been open for a long time and there has been no further reaction from you, we will now close it. If you do wish to investigate this further, feel free to post a new question or contact techsupport@skyline.be for assistance.
