Display Min, Max and Avg or a period of time
Solved1.24K views4th May 2023
Kristopher Brookshire [DevOps Member]220 3rd May 2023 0 Comments
We are trying to get a table like the one below that will provide the Min/Max/Avg for each test point over the course of a month.
Even though this says it is for the previous month it is just showing the latest values.
Is there a way for us to get Dataminer to provide what we are looking for in a report format?
Kristopher Brookshire [DevOps Member] Selected answer as best 4th May 2023
Wim Bruynooghe [SLC] [DevOps Advocate]6.77K Posted 4th May 2023 0 Comments
Since you’re still using the legacy Reporter:
In the template builder, configure the time range:
When selecting parameters to be included in the report, select which trend data it should add:
Or in Cube when configuring it in Automation or Correlation:
(when I tested this, Cube seems to apply the trending options on every selected parameter, that’s actually not expected)
In the result, separate columns should be added inside the column of the parameter with the Min, Max and Avg value:
Rene De Posada [SLC] [DevOps Advocate]1.93K Posted 3rd May 2023 0 Comments
Hi Kristopher,
With the pivot table (Pivot table | DataMiner Docs) in dashboards, you can easily achieve this behavior. Below you see an example where the Avg, Min and Max are shown for the Total Processor Load and Physical Memory of the server. Note that the time range can be configured by the user directly from the GUI using the Time Range component (Time range feed | DataMiner Docs) and passing it as feed to the Pivot table.
Rene De Posada [SLC] [DevOps Advocate] Answered question 3rd May 2023
