Display issue of a VIEW on a Visio
Solved996 views26th February 2025
Brian Reinhart [DevOps Enabler]20 20th February 2025 0 Comments
Hello community,
I created an overview VIEW that displays other views.
Everything works correctly except for one particular VIEW that refuses to display.
I tried recreating a new VIEW and reimporting my Visio, and I also tried creating a service and importing my visual, but the problem persists.
I haven't found any differences between the views that display and the one causing the issue.
If anyone has encountered this problem before, I would appreciate some help. Thank you.
Arunkrishna Shreeder [SLC] [DevOps Enabler] Answered question 26th February 2025
Toon Casteele [SLC] [DevOps Enabler]7.37K Posted 20th February 2025 1 Comment
I think your best bet is to reach out to our Technical Support team with details on the issue, attached Visio files and info on where it occurs.
If it looks like a one-off issue it will be difficult to assist over Dojo Questions.
Toon Casteele [SLC] [DevOps Enabler] Answered question 20th February 2025
Brian Reinhart commented 20th February 2025
Hi Toon,
I will contact the support.
Thanks
