Display current preset name in use by Spectrum element
Solved1.52K views24th April 2025spectrum analyzer
Alain Faivre [DevOps Member]276 21st April 2025 0 Comments
Hello Community,
I have a Spectrum component in a visio and I would like to add a shape displaying the current preset name in use by the spectrum analyzer.
What is the property/Parameter to be used for that ?
Thanks,
Alain Faivre [DevOps Member] Selected answer as best 24th April 2025
Miguel Obregon [SLC] [DevOps Catalyst]23.81K Posted 21st April 2025 1 Comment
Hi Alain,
A possible option is to visualize the preset using a session variable. For example, in the following Kata session (Using Visual Overview to switch spectrum presets), session variables are used to set the preset that will applied to the spectrum component. You can visualize the current preset applied to the spectrum by displaying the session variable in a separate shape. Below a small example:
In this example, I defined a different reference level per preset. You will notice that the reference level will change from -20 dBm to -40 dBm.
Hope it helps.
Alain Faivre [DevOps Member] commented 22nd April 2025
Thanks Miguel. I had already tried this and will use it as a workaround.
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.41K Posted 21st April 2025 1 Comment
Hi Alain,
Does this page Embedding a Spectrum Analysis component | DataMiner Docs help you ?
Alain Faivre [DevOps Member] Posted new comment 21st April 2025
Alain Faivre [DevOps Member] commented 21st April 2025
Hi Arunkrishna,
In fact, I already have the Spectrum component embedded into my visio.
There are several traces which alternate and I would like to display in a separate shape the preset which is currently used by the spectrum (i.e. corresponding to the trace displayed). Thank you
