Display consolidated data for multiple DMA monitoring protocol(MS platform).
Solved731 views11th September 2025dasboards Dashboads dashboard chart multiple items
Raghav Nanda44 4th April 2025 0 Comments
I was trying to display several parameters from the MS Platform protocol for various DMAs. I was able to display the data successfully for one DMA node. I was looking for the best way to create a dashboard that would show me same parameters from all the DMAs. So far I added components(for each parameter) for each DMA. Please Let me know if anyone knows a better way to achieve the same.
Please Find below a sample which I am trying to achieve.
Miguel Obregon [SLC] [DevOps Catalyst]22.32K Posted 4th April 2025 0 Comments
Hi Raghav,
If you plan to implement this visualization in a Visio overview, you could use Generate shapes for a predefined set of elements.
If you plan to implement this visualization in a dashboard/LCA, you could use a grid component. Using GQI queries you can retrieve information from elements using the Microsoft Platform connector(using the data source Get Elements) and their corresponding KPIs (using the data source Get parameters for elements where)
Hope it helps.
