Discreet Values Not Reflecting Custom Status Labels
Solved1.63K views5th November 2025
Rachel Andrews130 16th April 2025 2 Comments
Hi everyone,
I’m using a discreet parameter in my connector to display HTTP status codes. However, even though I’ve defined discreets for values like 200, 400, etc., the parameter still displays the raw value (HTTP/1.1 200) instead of the label I want (like OK or Bad Request).
Here’s what I’d like to display:
  • 200 → OK
  • 400, 403, 404 → Bad Request
How can I fix this so the parameter shows the discreet label (e.g., OK) instead of the raw value? Can you share an example where this worked as expected?
Thanks in advance
Marieke Goethals [SLC] [DevOps Catalyst] commented 11th September 2025
I see that this question has been inactive for some time. Do you still need help with this? If not, could you select the answer that has been most helpful (using the ✓ icon) to indicate that no further follow-up is needed?
João Severino [SLC] [DevOps Enabler]14.78K Posted 16th April 2025 2 Comments
Hi Rachel,
Could you share your parameter XML definition?
Sometimes the HTTP status code received from an HTTP session contains more than just the code number, and if you just defined 200 as a value and received HTTP/1.1 200 then it will not map it to the string OK you defined in the Display tag.
Rachel Andrews commented 16th April 2025
Hi Joao, I did do this however its still showing HTTP/1.1 200. Also how can I pass 404 and 403 ad bad request as well.
Stream Viewer:
<- 11:48:05 – GET https://url:443/api?endpoint
-> 11:48:06 – HTTP/1.1 200
<Param id="103" trending="false">
<Name>StatusCode</Name>
<Description>Status Code</Description>
<Type>read</Type>
<Information>
<Subtext>Status Code</Subtext>
</Information>
<Interprete>
<RawType>other</RawType>
<Type>string</Type>
</Interprete>
<Alarm>
<Monitored>true</Monitored>
</Alarm>
<Display>
<RTDisplay>true</RTDisplay>
</Display>
<Measurement>
<Type>discreet</Type>
<Discreets>
<Discreet>
<Display>OK</Display>
<Value>HTTP/1.1 200</Value>
</Discreet>
<Discreet>
<Display>Bad Request</Display>
<Value>HTTP/1.1 400</Value>
</Discreet>
</Discreets>
</Measurement>
</Param>
João Severino [SLC] [DevOps Enabler] commented 16th April 2025
Hi Rachel,
At first glance, it looks like it is correct, although if you want to map multiple incoming values into a single display value, I would suggest considering using a QAction to do such mapping.
Very likely, one is already being used to process the HTTP response, so it could be expanded to include the processing of the status code.
Bram Devlaminck [SLC] [DevOps Advocate]942 Posted 16th April 2025 0 Comments
Hi Rachel,
The “value” tag in the discreet element expects an exact match.
As the value is “HTTP/1.1 200” and not just “200” DataMiner cannot find a match and does not know what to display. As a solution, it displays the “raw” value.
To resolve this, change your “value” in the discreet tag from “200” to “HTTP/1.1 200”
Do the same for 400, 403 & 404.
I think this should resolve your issue.
Best of luck!
Kind regards,
Bram Devlaminck [SLC] [DevOps Advocate] Answered question 16th April 2025
Michiel Vanthuyne [SLC] [DevOps Advocate]4.82K Posted 16th April 2025 0 Comments
Hi Rachel, I suspect some other part of your connector, like the QAction that processes the responses, is writing this raw value to the parameter instead of only the code number. You can either change the part that writes the value, or change the definition of the discreets so “HTTP/1.1 200” maps to “OK”.
Michiel Vanthuyne [SLC] [DevOps Advocate] Answered question 16th April 2025
