DIS Inject Project load
Solved1.61K views4th April 2024Automation DIS automation scripts DIS INJECT
Daniel Mainha [DevOps Member]304 2nd April 2024 0 Comments
I’ve created a new automation script with only one execution script as a Script Exe (Project).
I’m trying to use DIS Inject but it fails to load the project so i’m not able to inject the dll.
In turn, if I publish the same automation script into the dma and then import it, I’m able to load the project and inject the dll. Am I forgetting something? I’ve done this running VS as an Administrator.
  • Fails using the automation script project:
  • Works when importing the automation script from the dma:
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 4th April 2024
Michiel Oda [SLC] [DevOps Advocate]3.90K Posted 3rd April 2024 1 Comment
Hi Daniel
In your first screenshot you have the ‘RBM Resource Creator’ script open, but in the DIS Inject you have the ‘RBM Surveyor View Creator’ script selected. Could you check if it works when you have the correct script open?
Daniel Mainha [DevOps Member] commented 3rd April 2024
Nothing like a second pair of eyes. Didn’t see that it was the wrong script selected!
Thanks! Solved.
