DIS 3.1.6 Connection Issue
Solved2.31K views13th March 2025DIS Visual Studio
David Rid [DevOps Advocate]957 11th March 2025 0 Comments
My DIS is not connecting to the Dataminer Agent.
When I use the cloud path in DIS for upload, it works, but the conventional path over the IP address is not working.
I am running Windows 11 version 24H2 with the latest DIS version 3.1.6.
I downgraded the version back to 3.1.2, and it works fine now. This might be an issue for other users as well once they update their system.
Error message when trying to connect via IP address:
Error message when trying to publish:
System.ServiceModel.FaultException:
Message="System.ServiceModel.FaultException: System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 127.0.0.1:80
at System.Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
at System.Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
at System.Net.Http.HttpClientHandler.GetRequestStreamCallback(IAsyncResult ar)
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at Nito.AsyncEx.Synchronous.TaskExtensions.WaitAndUnwrapException[TResult](Task`1 task)
at SLDisDMAComm.SLDisDmaCommService.ConnectToWebApi() in D:\a\DIS\DIS\ProtocolEditor\SLDisDMAComm\SLDisDmaCommService.cs:line 1203
at SLDisDMAComm.SLDisDmaCommService.ConnectToWebApi() in D:\a\DIS\DIS\ProtocolEditor\SLDisDMAComm\SLDisDmaCommService.cs:line 1224
at SLDisDMAComm.SLDisDmaCommService.Connect(String hostname, String username, String password, String accessToken) in D:\a\DIS\DIS\ProtocolEditor\SLDisDMAComm\SLDisDmaCommService.cs:line 219"
Four days ago, this question was asked. It might be related:
how-to-install-older-version-of-dis-3-1-4
BR,
Amber Rowe [DevOps Advocate] Answered question 13th March 2025
Amber Rowe [DevOps Advocate]575 Posted 13th March 2025 1 Comment
I had the exact same issue - but Skyline has now released DIS version 3.1.7 - which for me, resolved the issue.
David Rid [DevOps Advocate] Posted new comment 13th March 2025
David Rid [DevOps Advocate] commented 13th March 2025
I tested it too and it seems everything is resolved.
Great! ^^
