Different Card Layouts Possible on Each Cube Side?
Solved1.81K views16th October 2024
Mark HOUSE100 16th February 2022 0 Comments
Hi - since our recent upgrade to v10.2, the operations team here have reported that it's no longer possible to have different card layouts on each of the Cube sides. For example, on the first side a proportional layout might be used, then on the second side, a workspace with a tab layout is activated. The problem reported is that the layout on the first side is now forced to a tab layout too. The team tell me this was not the case before the upgrade (each side kept its set layout). Unfortunately, I never tried this before so I can't confirm. Can anyone else comment on this?
Pieter Van Compernolle [SLC] [DevOps Enabler] Answered question 16th October 2024
Pieter Van Compernolle [SLC] [DevOps Enabler]3.89K Posted 16th February 2022 10 Comments
Hi Mark,
At first sight, the setting where we store the layout preference has always been a shared setting for all Cube sides. What probably did change is that setting the value in recent versions, immediately applies it on all cube sides and before it was only applied after a reconnect or in new sessions.
(I compared 10.2 with 10.0 here in my reference setups to come to that conclusion)
Pieter Van Compernolle [SLC] [DevOps Enabler] Posted new comment 18th January 2024
Pieter Van Compernolle [SLC] [DevOps Enabler] commented 16th February 2022
Feel free to share why it is important for your users to have different layouts on the different Cube sides.
Mark HOUSE commented 16th February 2022
Hi Peter, thanks for replying – just to be clear to me, are you saying it is possible to have different layouts in earlier versions, but only for a long as that session remains open? This would tie up with what was reported.
Gelber Mahecha [SLC] [DevOps Enabler] commented 16th February 2022
As a tip, you can press CTR + L to quickly switch the layout with a couple of keystrokes.
Ben Vandenberghe [SLC] [DevOps Advocate] commented 16th February 2022
Indeed, these short cuts are really worth learning about. Also CTR+Q to get a navigation menu to easily switch between cards or workspaces.
Pieter Van Compernolle [SLC] [DevOps Enabler] commented 17th February 2022
Hi Mark,
Yes, that is what I meant. Can you share the version you came from, then I can double check for you.
Show 5 more comments
