devops dataminer guide
Solved1.70K views30th October 2023
praveen sajja [DevOps Member]86 25th May 2023 0 Comments
hi team
we going to use dataminer, and i was the Devops engineer, i want to know like how can we setup dataminer environment, so that our devlopers will work on it. and also i need an installation guide for setting up dataminer and related to CI/CD also what we have to do?.
i have many more questions to ask , it will be very helpfull,if we have a connect on call
thanks
s.j.v.praveen
Erdal Gurses Answered question 30th October 2023
Danielle Falcone [SLC] [DevOps Advocate]1.49K Posted 25th May 2023 3 Comments
Hello Praveen,
To install DataMiner you should first download the software, here you can download what you need: DataMiner Software – DataMiner Dojo
Probably you will do the first installation, so it will be this option:
When you select this download, you will have access to the instructions, see screenshot below:
As far as you are starting with DataMiner, I would also recommend to follow the courses DataMiner Foundational: DataMiner Foundational – DataMiner Dojo
And take a look at the documentation: Getting started with DataMiner | DataMiner Docs
Success!
Regards,
Danielle
praveen sajja [DevOps Member] commented 25th May 2023
hi Danielle Falcone
point1. i have to install dataminer in remote server, in that case how can i do.
point2. in requirements at OS only windows symbols was there, we cant install dataminer in linux.
point3. comming to database, i have to install database casendra or elastic in same server where dataminer was running?, can i use use external database out side the server where dataminer was running, for example i was installing dataminer in compute instance on GCP cloud but i want to use google cloud cassandra database is it possible?
Arunkrishna Shreeder [SLC] [DevOps Enabler] commented 25th May 2023
1. You place the DataMiner installer on the server and then install.
2. Correct, DataMiner cannot yet be installed on Linux.
3. You can have your database hosted on external servers. You have to make the configuration accordingly.
Danielle Falcone [SLC] [DevOps Advocate] commented 25th May 2023
just adding the links to the documentation:
2. https://community.dataminer.services/dataminer-compute-requirements/
see “Operating System”
3. https://docs.dataminer.services/user-guide/Advanced_Functionality/Databases/Databases_about.html
Erdal Gurses41 Posted 30th October 2023 0 Comments
Hi Team,
Does Dataminer supports the EVERZ MVP 3000 Multivier ?
Best Regards.
