Deleting Element Data From a Cassandra DB
Solved1.20K views18th July 2023Cassandra
Nigel Scrivin [DevOps Member]96 16th September 2021 0 Comments
I have an element that seems to be holding old table data that no longer exists. Is there a delete statement or command that can be used with Cassandra to delete data for a specific element and /or a specific table from an element?
Alberto De Luca [DevOps Enabler]5.36K Posted 16th September 2021 0 Comments
Hi Nigel, some protocols have the “Clear Missing” command in the element card, on the top of the table – this helps when clearing rows related to e.g. input feeds no longer existing on the device – some have also an Auto-Remove feature.
If data is no longer on the element, but just stored within the local DB of the DMA, you’d need the Cassandra query to remove it – is it trend or alarms?
Best checked with your deploy-squad I guess.
