Delete element from protocol code
Solved1.79K views30th May 2023delete elements protocol
Thibault Heylen [SLC] [DevOps Member]1.51K 30th May 2023 0 Comments
Hi all,
What is the preferred way of deleting an element from  protocol code?
Is this using the NT_DELETE_ELEMENT(5), or is their a direct command for this?
Thank you in advance.
Thibault Heylen [SLC] [DevOps Member] Selected answer as best 30th May 2023
Joachim Ally [SLC] [DevOps Advocate]1.64K Posted 30th May 2023 1 Comment
Hi Thibault,
Here is a piece of code that can serve as an example
IDms dms = protocol.GetDms();
var dmsElementID = new DmsElementId("5");
var element = dms.GetElement(dmsElementID);
element.Delete();
For this to work, you need to include this NugetPackage in your QAction : Skyline.DataMiner.Dev.Protocol and use the namespace with
using Skyline.DataMiner.Core.DataMinerSystem.Common;
using Skyline.DataMiner.Core.DataMinerSystem.Protocol;
using Skyline.DataMiner.Scripting;
Kind regards,
Joachim
Joey Vanhalst [SLC] [DevOps Advocate] Posted new comment 30th May 2023
Joey Vanhalst [SLC] [DevOps Advocate] commented 30th May 2023
Note that it’s the “Skyline.DataMiner.Core.DataMinerSystem.Protocol” NuGet that you’ll need for this.
