Delay in connecting with Cube client
Solved2.30K views6th August 2021Cube connect DataMiner Cube
6
Ben Vandenberghe [SLC] [DevOps Advocate]9.77K 6th August 2021 0 Comments
Since a while I’m experiencing a long time to connect with Cube to some of my DataMiner Systems.  The launcher seems to spend a long time on connecting / checking version on server / …  This must be related to my setup, because others in the same environment do not experience this.
Any suggestions on what to check?
Ben Vandenberghe [SLC] [DevOps Advocate] Selected answer as best 6th August 2021
Jan Vanhove [SLC] [DevOps Member]1.23K Posted 6th August 2021 1 Comment
A possible reason for this:
If your DMS is configured to only allow HTTPS, and the config in your Cube Start Window is still referring to HTTP, then the start of your cube session will indeed be delayed.
A possible fix is to recreate the start-window button to connect immediately to HTTPS.
Ben Vandenberghe [SLC] [DevOps Advocate] Posted new comment 6th August 2021
Ben Vandenberghe [SLC] [DevOps Advocate] commented 6th August 2021
Brilliant, that fixed it indeed. I had this configured with HTTP in the past, and in the meanwhile the underlying DataMiner System was indeed changed to HTTPS only. I removed that system from my Cube Launcher, and added it again. It automatically detected the HTTPS while doing that. And it works like a charm now, and launches instantly again. Thanks! Appreciate the swift response.
