Defining specific view of an element in CSV import
Solved722 views27th April 2025
Charlene Ladines [DevOps Member]56 12th February 2025 0 Comments
I am planning to provision multiple similar elements in Dataminer by importing an edited csv file that I have exported. Is there a way to define the view where I want each element to be included in csv file? Since I need to put the elements on their respective sites.
Regards,
Charlene
Arunkrishna Shreeder [SLC] [DevOps Enabler] Selected answer as best 27th April 2025
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.28K Posted 12th February 2025 0 Comments
Hi Charlene,
If you open the csv export file, there will be a column called View IDs. There you need to mention the view ID of the target DMA’s view where you want to import the element.
Do note that DELT exports are preferred over csv exports as the latter has some limitations.
Exporting and importing packages on a DMA | DataMiner Docs
