DCF – How to display an Interface Property?
Solved1.13K views30th August 2024Connection Property DCF Interface Property
Trong Huynh [DevOps Advocate]881 2nd July 2024 1 Comment
I can work out how to display a Connection Property on the Visual Display. But how do you display a Interface Property?
For my case, each interface as its own IP address. I want to show the IP address next to its interface.
Is that possible?
Thanks!
Trong Huynh [DevOps Advocate] Selected answer as best 30th August 2024
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th August 2024
I see that this question has been inactive for some time. Do you still need help with this? If yes, could you answer the questions Toon asked below? Or if not, could you select his answer (using the ✓ icon) to indicate that the question is resolved?
Toon Casteele [SLC] [DevOps Enabler]7.37K Posted 2nd July 2024 2 Comments
Assuming you're referring to interfaces that come from a table parameter, you can link to different parameters from that same interface row with the InterfaceParameter template shape.
Create a simple shape anywhere in your page, set its Options shape data to InterfaceParameter:<paramID> and put "*" in the shape text.
NOTE: It's been a while since I set this up myself so I hope I interpreted the help and remembered correctly. Let me know if it's not working and I'll try to set something up locally.
Trong Huynh [DevOps Advocate] commented 8th July 2024
Thanks, Toon, for the response. I’m still unable to get it to work though.
Toon Casteele [SLC] [DevOps Enabler] commented 9th July 2024
Could you provide us with some more info by editing your original question? Where are the interfaces defined, what are you trying to achieve, what have you tried in Visual Overview…? Thanks.
