DCF Automation
Solved1.33K views26th June 2025Automation dataminer connectivity framework DCF
Ross Elliott [DevOps Advocate]1.15K 3rd February 2025 0 Comments
Hi, is DCF included in the automation Class Library? I can see from questions in the past that it was requested a few times, and Skyline.DataMiner.Core.ConnectivityFramework.Protocol was released to add functionality for connectors but I'm having trouble finding anything for automation.
I'm looking to automate a video router network, I need to get dcf connections so I can set the router x points based on inputs/outputs to other routers.
An example would be, user presses 'route to analyser' on a LCA. A script looks at DCF and builds a route from the source through router x and router y to get to destination router z and sets all the cross-points.
Is there a way I can achieve this? Is there an slnet message I can send to get/edit DCF connections?
Thanks,
Ross
Miguel Obregon [SLC] [DevOps Catalyst]22.41K Posted 4th February 2025 1 Comment
Hi Ross,
There is a Kata session related to DCF where we used the Skyline Generic Provisioning connector to import/export DCF connections (using a CSV file). For example, your automation script can programmatically populate this CSV file and use the connector to provision the DCF connections.
Hope it helps.
Ross Elliott [DevOps Advocate] commented 7th February 2025
Good idea I will take a look, thanks.
