DataMiner vs. others (How dataminer differentiates than others)
Solved8.70K views6th July 2021DataMiner positioning DataMiner strengths DataMiner vs. others
21
Daud Ahmed0 30th June 2021 2 Comments
We are engaged to propose dataminer for a project to our customer. There are multiple teams where they have different opinions also questioning that dataminer is little costly. Sometimes end customer starts comparing Dataminer with some specific companies who provides monitoring tools just for limited segment and tend to say that we can monitor and manage every single element of the ecosystem similar to what dataminer does. How does dataminer stands special? Can you help us with some intakes to share the right message to my customer here?
pramod Gupta [SLC] [DevOps Member] Posted new comment 6th July 2021
Daud Ahmed commented 6th July 2021
Thank you very much team for response. Explained very well and it will be very helpful to explain the customer. Also after seeing all the offering from dataminer it will be unfair to compare any other monitoring tool to dataminer.
Thanks.
pramod Gupta [SLC] [DevOps Member] commented 6th July 2021
Thanks Daud, much appreciated.
Ben Vandenberghe [SLC] [DevOps Advocate]9.77K Posted 4th July 2021 0 Comments
This illustrates some of the points I raised in the earlier response, I thought it might help.
Ben Vandenberghe [SLC] [DevOps Advocate] Answered question 4th July 2021
You are viewing 1 out of 7 answers, click here to view all answers.
