DataMiner versions for ATEME AMS?
Solved2.14K views29th September 2021AMS Ateme DataMiner 10
Alberto De Luca [DevOps Enabler]5.75K 29th September 2021 0 Comments
I have an AMS running DM v 9 - I was wondering if the underlying DMS can be upgraded to DataMiner 10: any recommendations? Any contact from Ateme here on the Dojo?
Didier Schepens [SLC] [DevOps Member] Answered question 29th September 2021
Didier Schepens [SLC] [DevOps Member]202 Posted 29th September 2021 1 Comment
Hi Alberto,
Technically spoken the underlying DMA can be upgraded. However since AMS is distributed by Ateme and it is running their own applications, version control is also in the hands of Ateme.
We recommend to contact Ateme. Contacts can not be found on Dojo but we can help you with that if required.
Alberto De Luca commented 29th September 2021
Thanks for the prompt feedback, Didier.
Will reach out with the info from this DMS.
