Dataminer takes too much time to load after restarting
Solved779 views20th February 2026Dataminer slowness
Mohan Ramasamy Veerappan [DevOps Member]190 25th July 2025 3 Comments
Hi Dojo
Anybody suggest / advice please, I'm not sure why Dataminer takes too much time to load after restarting even small number of elements & protocols it has.
Even the logs don't have any clue.
Note: It took more than 20 mins to load.
Could you please check the screenshot below,
Thanks
Mohan RV
José Silva [SLC] [DevOps Enabler] commented 28th July 2025
Hi Mohan,
Could you mention which DataMiner version you're using? That will help others in the community assist you more effectively.
Kind regards,
Hi Mohan,
Mohan Ramasamy Veerappan [DevOps Member]190 Posted 28th July 2025 2 Comments
Hi Jose
We are using Dataminer version : 10.5 CU2. Please check the screenshot.
Thanks
Mohan RV
Miguel Obregon [SLC] [DevOps Catalyst] commented 31st July 2025
Hi Mohan,
I would suggest to contact Techsupport team (techsupport@skyline.be) to further investigate the issue that your are experiencing.
Mohan Ramasamy Veerappan [DevOps Member] commented 11th August 2025
Hi Miguel
Yes I did and waiting for their reply.
Thanks
Mohan RV
