Dataminer System Credentials and Access
Solved2.00K views17th July 2023
Matthew Smith70 22nd November 2021 0 Comments
Our Dataminer systems are currently using user accounts on the local Windows 2012 Servers. Our security team is requesting that all credentials of operational systems within our organisation are managed centrally by an Identity and Access Management service. Does anybody have any experience if this would be a problem for a Dataminer based system?
Michiel Vanthuyne [SLC] [DevOps Advocate]4.82K Posted 22nd November 2021 1 Comment
Hi Matthew,
DataMiner supports several options for centralized authentication: LDAP, SAML, RADIUS, and Crowd authentication. You can find an overview of the possibilities in the help pages here.
Matthew Smith Posted new comment 22nd November 2021
Matthew Smith commented 22nd November 2021
Hi Michiel,
Ok, good to know. I will communicate this to our security team. Thanks a lot for the fast reply.
