Dataminer System Credentials and Access
Solved2.21K views17th July 2023
Matthew Smith70 22nd November 2021 0 Comments
Our Dataminer systems are currently using user accounts on the local Windows 2012 Servers. Our security team is requesting that all credentials of operational systems within our organisation are managed centrally by an Identity and Access Management service. Does anybody have any experience if this would be a problem for a Dataminer based system?
Gellynck Jens [SLC]2.73K Posted 22nd November 2021 1 Comment
Hi Matthew,
This should not be a problem, DataMiner supports several Identity and Access Management services (for example Active Directory, CROWD). DataMiner also supports SAML authentication, meaning any Identity Provider that supports the SAML standard can integrate with DataMiner (for example Azure AD, AD FS, Okta). Providers like Azure AD allow you to enable Multi-Factor Authentication.
Users can be stored in any directory that supports LDAP (Active Directory, OpenLDAP,...)
Matthew Smith commented 22nd November 2021
Hi Jens,
Ok, good to know. I will communicate this to our security team. Thanks a lot for the fast reply.
