DataMiner Prediction engine
Solved3.42K views19th July 2023prediction trending
Jeyaram Sumanthiran30 9th December 2020 0 Comments
I could see the prediction on the trend graph. Just curious to understand the logic behind.
Matthias Van Onsem [SLC]10 Posted 9th December 2020 1 Comment
With forecasting, the main goal is to provide users with a quick overview on future behavior and predict alarms based on that with our proactive alarm detection engine.
Forecasting does not use a “one model fits all” approach, but rather generates a model based on the behavior of each parameter. This uses a combination of our own “Fortress” model, which dissects the data into a level, a trend and a periodic component, and a model based on SARIMA, which by itself incorporates 4 different prediction models.
DataMiner is able to adapt these models to a greater extent than similar approaches you might find in academic papers however. Periodic behavior is automatically extracted via autocorrelation plots, transformation to a stochastic series is automatically done via both linear and nonlinear transformations, and even the model structure itself is also generated in a fully automated way based on parameter behavior. The training itself also analyses certain values and devalues them if it is deemed not useful to incorporate them fully in the forecasting model.
Because a lot of the forecasting model generation is data-driven, typical DataMiner systems have hundreds of different models specifically tailored to certain parameter subsets. They are also able to adapt to concept drift, meaning if the behavior of the parameter changes, the model for that parameter will rewrite itself.
Besides that, we are also aware that certain impulses might be important to one parameter, but be noise to others. Therefore, DataMiner merges information of different resolution wavelets to improve its accuracy, which plays a crucial role in other proactive features such as alarm forecasting.
Lastly, as there is always a level of uncertainty present in parameter behavior that is impossible to model mathematically, DataMiner also provides confidence bounds, which shows how the data could fluctuate at different degrees of certainty. These confidence bounds are calculated using statistical properties of the parameter behavior.
Wale Oguntoyinbo [SLC] [DevOps Advocate] commented 10th December 2020
Sounds complex and intriguing. Thanks for this insight.
