Dataminer on Nutanix Virtual Machine
Solved1.16K views25th July 2023
MOHAMMED SAFRI MAHMUD42 1st June 2023 0 Comments
Hi All, I wish to explore the Dataminer deployment over virtual machine (VM).
I'm currently operating Nutanix AHV 6.12 LTS virtual machine in my facility.
Would you be able to advice what are the requirements to do so?
MOHAMMED SAFRI MAHMUD Selected answer as best 25th July 2023
Baptiste Pattyn [SLC] [DevOps Advocate]5.85K Posted 20th June 2023 0 Comments
As Nutanix supports Windows based VMs it should be possible to run DataMiner on this platform. Note that we have not validated this, I am merely giving you this answer based on the information found on this specific VM Hypervisor.
